DaddyMac2
Oct 17, 2018Tutor
EX7500 Range extender drops connections
I have the EX7500 range extender and the X10 router. The range extender is consistently dropping connections and needs to be re connected to the router to fix. I have tried changing channels and th...
trf000
May 20, 2019Tutor
Yeah, same issues as above, but some extra. I have two Roku TV's in 2 bedrooms, and another in my living room. When one bedroom tv is connected to the 5g network, the other is blocked from it forcing it to the 2.4 g network.
house is 2400 square feet, router is in the middle of the house in the back, 10 feet in the air. Extender is about 35 feet away, in an outlet that is about 7 feet up. There are two walls between the extender and the router. It constantly drops connections and freezes all the tv's.
Did a factory reset on both the router and extender, forgot all the old connections, created new ones. same issue. If the answer is buy more, then someone else will be getting my money.
