DaddyMac2
Oct 17, 2018Tutor
EX7500 Range extender drops connections
I have the EX7500 range extender and the X10 router. The range extender is consistently dropping connections and needs to be re connected to the router to fix. I have tried changing channels and th...
ArnaudB
Nov 09, 2019Aspirant
Hello,
I also had the same problem.
Shortly I had to reinstall the WiFi because I had issues with my provider.
Since then I changed the WiFi channel for 5ghz from 100 to 104.
It’s been one week now since I experienced no more disconnection.
Maybe this can help anyone else.
