DaddyMac2
Oct 17, 2018Tutor
EX7500 Range extender drops connections
I have the EX7500 range extender and the X10 router. The range extender is consistently dropping connections and needs to be re connected to the router to fix. I have tried changing channels and th...
donkeybidder
Feb 20, 2020Aspirant
Hi Thanks,
Do you have you the Schedule option running which cuts the Wi-Fi service on the router and then reconnects as a predetermined time?
As once mine connects all is fine just fail to connect when the Router Wi-Fi comes back on again!
Thanks
DaddyMac2
Feb 20, 2020Tutor
Nope, I didn't have mine set. I have since gotten rid of that device as it failed to do what it was supposed to
