DaddyMac2
Oct 17, 2018Tutor
EX7500 Range extender drops connections
I have the EX7500 range extender and the X10 router. The range extender is consistently dropping connections and needs to be re connected to the router to fix. I have tried changing channels and th...
ArnaudB
Nov 09, 2019Aspirant
Hello,
I also had the same problem.
Shortly I had to reinstall the WiFi because I had issues with my provider.
Since then I changed the WiFi channel for 5ghz from 100 to 104.
It’s been one week now since I experienced no more disconnection.
Maybe this can help anyone else.
donkeybidder
Mar 13, 2020Aspirant
Hi,
End up sending it back to Amazon and updating to the EX8000, works perfectly no issue dropout or unable to connect after Time Schedule disconnect and reconnect.. Therefore, looks like The EX7500 has issue the unit is unfit for the purpose intended...
ArnaudB wrote:
Hello,
