dsws67's avatar
dsws67
Initiate
Jan 08, 2024
EX7700 can't set admin password after factory reset
Hi community,
I needed to do the hard reset on my Extender EX7700. After reset I could connect via WPS to my Nighthawk R700 router and also a firmware update was done to v1.0.0.226.
After accessing mywifiext.local I got the screen to configure my new extender.
Then I filled out admin-User-Name, passwort and the 2 recovery questions. And then "hourglass / turning cycle" appeared and nothing happend anymore.
I tried the connection via Wifi and LAN, with 2 different computers and 3 browser => always the same:
I can't pass the admin-user-creation screen.
Could anyone help for solutions or walk-arounds?
Kind regards
Daniel
  • I got the solution which is a bit weired.
    The problem was that I used non-english letters in the answers of the security questions. If you use e.g. this letter "ä" the admin-account-creation is not working. If you use "a" everything is fine.
  • plemans's avatar
    Are you able to go through the password recovery option?
    Maybe the password you set didn't meet requirements (for some reason) and caused issues
    • dsws67's avatar
      dsws67
      Initiate
