brettdorron's avatar
Apr 10, 2022
EX7700 keeps factory resetting every few weeks. Loses all settings.
I have an EX7700 that keeps factory resetting every few weeks. It serves as both wifi extender and connects my wireless and wired ethernet LANs, including my NASs, in my home office.  It is 12 months old later this month and in the past few months it has started periodically forgetting all settings and returning to factory reset state every few weeks.
I have reset it myself and updated firmware etc. I'm not sure what else I can try. Any advice? Has anyone else had or heard of this happening?
Thanks
  • plemans's avatar
    something to try is to reinstall the firmware to it and then do a factory reset yourself.
    Reason why is if something is corrupt in firmware, the reinstall over-writes the firmware. If something is corrupt in the settings, the factory reset clears that. Maybe its "resetting" isn't clearing everything out.
    • brettdorron's avatar
      brettdorron
      Tutor
      Cool. Thanks plemans,
      I've factory reset a couple more times and I "did" encounter problems trying to reinstall firmware. Maybe there was a problem with the previous firmware update. Time will tell. I was able to force a firmware reinstall, eventually. For now, it is working again. I'll come back if it fails again.
      Thank you.
