Gihan's avatar
Gihan
Tutor
Dec 06, 2020
EX7700 mesh extender - work with 2.4GHz only router
My main router only has the 2.4GHz band. Will this extender provide 5GHz bands and maintain the FastLane if I configure to use with that?
Thanks,
Gihan
  • You can set it to run off the 2.4ghz for the fastlane. Issue is the 2.4ghz is still the limiting factor. You're not going to see faster 5ghz speeds because of the bottleneck being 2.4ghz.
    You'd be better off to hardwire in the EX7700 and run it in access point mode.
  • plemans's avatar
    • plemans's avatar
      Or upgrade the router before upgrading the extender.
      • Gihan's avatar
        Gihan
        Tutor
        Thanks for the reply plemans. I got this router FoC from my ISP along with a Fiber connection. Unfortunately they don't have 5GHz option. I'll check with the wired option. Thanks again.
