glocker
Apr 04, 2018Aspirant
EX8000 - Connected Devices - Signal Strength
EX8000 extender is connected to an X10 (R9000) router. Three mobile devices are connected to the extender. After logging into the extender, the Settings-Connected Devices page shows stats for the 3...
jvasanth1984
Apr 05, 2018Virtuoso
Hi glocker,
What phone and app are you using to check the signal strength on the phone?
glocker
Apr 05, 2018Aspirant
The Netgear wifi Analyzer, Net Analyzer, and analiti
- idark77Apr 05, 2018Star
I had a lot of issue with the last firmware (1.0.0.126) so I downgraded to 1.0.0.118, that is more stable for me. If you tried to reset the device with no success, you can try to downgrade and see if it works better.
