VernonX
Aug 04, 2018Guide
EX8000 5ghz channel selection for connection to router
I use a R8500 router with Smart Connect selected for 5ghz. I use the EX8000 as a (expensive) wireless switch (meaning I have no wireless clients for the EX8000, only ethernet conntected devices)--bo...
DexterJB
Aug 07, 2018NETGEAR Moderator
Hi VernonX,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
- sti11duecesNov 15, 2018AspirantI'm also having this issue. Been so disappointed with this device.
- sti11duecesNov 17, 2018AspirantWhat is the solution to this issue?
- Roofer4LifeJan 03, 2019GuideI also would like to know the solution
- Roofer4LifeJan 03, 2019GuideI also would like to know the solution.
I have a similar setup to you with my XR500- VernonXJan 04, 2019Guide
I have a similar setup to you with my XR500I went several rounds with tech support to no avail. I am not in the netgear debugging business until they pay me for my time. I have a more serious problem with the device dropping (alarm system) device connections on the ethernet ports. I've resigned myself to the fact that Netgear is no longer the high quality (high price) vendor I had come to believe in.
