VernonX
Aug 04, 2018Guide
EX8000 5ghz channel selection for connection to router
I use a R8500 router with Smart Connect selected for 5ghz. I use the EX8000 as a (expensive) wireless switch (meaning I have no wireless clients for the EX8000, only ethernet conntected devices)--bo...
sti11dueces
Nov 17, 2018Aspirant
What is the solution to this issue?
Roofer4Life
Jan 03, 2019Guide
I also would like to know the solution.
I have a similar setup to you with my XR500
- VernonXJan 04, 2019Guide
I have a similar setup to you with my XR500I went several rounds with tech support to no avail. I am not in the netgear debugging business until they pay me for my time. I have a more serious problem with the device dropping (alarm system) device connections on the ethernet ports. I've resigned myself to the fact that Netgear is no longer the high quality (high price) vendor I had come to believe in.
