youngnmoon
Jul 02, 2020Aspirant
EX8000 AC3000 Tri-Band WIFI Range Extender wont work with Apple devices
Any Apple products hooked to the extender do not connec to internet. They do connect to the extender, but there is no network connection to internet. Mircosoft computers and Android devices work just fine with either network, but the range extender will not let Apple products connect to internet.(Macbook ,IPAD ,Iphone ) I've reset everything numerous times, reset factory default and programmed again, etc, all with no improvement.
Which router are you connecting the extender to?
What firmware is on the extender?
Did you set it up using the installation assistant or using the wps install method?
What wireless security method are you using?
- youngnmoonAspirant
1.Router model is Verizon G3100
2.Firmware is 1.0.1.202
3.I use installation assistant (mywifiext)
4.Wireless Security Type is
WPA + AES I chose 2nd option in setting in installation assistant
try using WPA2-PSK
