ryantonk
Nov 06, 2018Tutor
ex8000 extender 5ghz connection
I cannot get my EX8000 to connect to my home routers 5ghz channel, it will only connect to the 2.4ghz channel. I have a AC1750 / C6300 home router. I have tried changing 5ghz channels on the router a...
DexterJB
Nov 07, 2018NETGEAR Moderator
Hi ryantonk,
Welcome to the community!
1. What is the firmware version of the extender?
2. Do you have other devices that are able to connect to the 5GHz band of the C6300?
3. Have you tried resetting the extender?
4. Was it working before?
5. Are you getting an error message? If yes, what is the error message?
Dexter
Community Team
- flyturboNov 11, 2018Apprentice
Come on Dexter!!! Why do you keep on wasting everyone's time??? Stop doing that please, start advising people who are experiencing issues with disconnects and/or no Internet with the EX8000 to simply return the units. I have been with tech support and Netgear engineers since July 2018 (80+ hours on the phone and troubleshooting) and nothing they asked me to do or latest firmware update have solved any of the issues.
What you should be telling everyone is to return the units ASAP. Please be honest with us.
NB: I'll be taking a screen capture of this post in the event it gets removed.
- StephenBNov 11, 2018Guru - Experienced User
flyturbo wrote:
but they certainly aren't going to tell people to return their units.NB: I'll be taking a screen capture of this post in the event it gets removed.
Netgear certainly isn't going to tell people to return their units because of a firmware issue. I get that you are angry, but you are basically spamming a bunch of different threads. If I ran the forum, I would delete many of your posts. Netgear tolerates at lot of criticism in these forums.
I suspect that there is a fair amount of activity behind the scenes on these recent firmware issues. Netgear generally doesn't anything about fixes that are in progress - not an approach I agree with myself, but since the mods are Netgear employees, they need to follow Netgear policies on public communications.
I'm spamming? Why did you post this reply publicly? Not surprised and was expecting you to make a comment on my posts. Wait, you can't get any attention anywhere else!
I'm offering others my experiencing with this unit, what exactly did you accomplish with your reply. I don't care about Netgear' s employees or policies, I know how it works and your reply was a real waste of time and useless. What I do care about is that others do return their unit because of what I have gone through. .
- ryantonkNov 12, 2018Tutor
1. Firmware is the latest
2. yes, other devices are able to connect to the routers 5ghx
3. yes, i reset it
4. i honeslty dont know if it was working before, i only recent checked it
5. no error messages, it simply doesnt connect.
One other thing is that i also changed the 5ghz channel on the router, that still didnt work.
I called Netgear, and they agreed to send me a warranty replacement extender. I can only hope that it will connect and doesnt have the same issue.
- flyturboNov 12, 2018Apprentice
3. yes, i reset it
I also had to request a replacement unit and unfortunately it made no difference. My unit was purchased in late in April, I can't get refund from Amazon, but I did request a full refund from Netgear and it as been approved. Now I have been testing the the extender with fixed Channels and it seems to be holding up. Today marks 3 days and no disconnects with firmware 1.0.1.180 but I with the latest firmware, I experienced the same issues.
- ryantonkNov 14, 2018TutorI received my warranty replacement extender, but it too doesn't connect to 5ghz. This thing is a piece of junk
