ryantonk
Nov 06, 2018Tutor
ex8000 extender 5ghz connection
I cannot get my EX8000 to connect to my home routers 5ghz channel, it will only connect to the 2.4ghz channel. I have a AC1750 / C6300 home router. I have tried changing 5ghz channels on the router a...
flyturbo
Nov 11, 2018Apprentice
Come on Dexter!!! Why do you keep on wasting everyone's time??? Stop doing that please, start advising people who are experiencing issues with disconnects and/or no Internet with the EX8000 to simply return the units. I have been with tech support and Netgear engineers since July 2018 (80+ hours on the phone and troubleshooting) and nothing they asked me to do or latest firmware update have solved any of the issues.
What you should be telling everyone is to return the units ASAP. Please be honest with us.
NB: I'll be taking a screen capture of this post in the event it gets removed.
Nov 11, 2018Guru - Experienced User
flyturbo wrote:
but they certainly aren't going to tell people to return their units.NB: I'll be taking a screen capture of this post in the event it gets removed.
Netgear certainly isn't going to tell people to return their units because of a firmware issue. I get that you are angry, but you are basically spamming a bunch of different threads. If I ran the forum, I would delete many of your posts. Netgear tolerates at lot of criticism in these forums.
I suspect that there is a fair amount of activity behind the scenes on these recent firmware issues. Netgear generally doesn't anything about fixes that are in progress - not an approach I agree with myself, but since the mods are Netgear employees, they need to follow Netgear policies on public communications.
- flyturboNov 11, 2018Apprentice
I'm spamming? Why did you post this reply publicly? Not surprised and was expecting you to make a comment on my posts. Wait, you can't get any attention anywhere else!
I'm offering others my experiencing with this unit, what exactly did you accomplish with your reply. I don't care about Netgear' s employees or policies, I know how it works and your reply was a real waste of time and useless. What I do care about is that others do return their unit because of what I have gone through. .
