ryantonk
Nov 06, 2018Tutor
ex8000 extender 5ghz connection
I cannot get my EX8000 to connect to my home routers 5ghz channel, it will only connect to the 2.4ghz channel. I have a AC1750 / C6300 home router. I have tried changing 5ghz channels on the router a...
flyturbo
Nov 12, 2018Apprentice
ryantonk wrote:
1. Firmware is the latest
2. yes, other devices are able to connect to the routers 5ghx
3. yes, i reset it
4. i honeslty dont know if it was working before, i only recent checked it
5. no error messages, it simply doesnt connect.
One other thing is that i also changed the 5ghz channel on the router, that still didnt work.
I called Netgear, and they agreed to send me a warranty replacement extender. I can only hope that it will connect and doesnt have the same issue.
I also had to request a replacement unit and unfortunately it made no difference. My unit was purchased in late in April, I can't get refund from Amazon, but I did request a full refund from Netgear and it as been approved. Now I have been testing the the extender with fixed Channels and it seems to be holding up. Today marks 3 days and no disconnects with firmware 1.0.1.180 but I with the latest firmware, I experienced the same issues.
ryantonk
Nov 14, 2018Tutor
I received my warranty replacement extender, but it too doesn't connect to 5ghz. This thing is a piece of junk
- DexterJBNov 14, 2018NETGEAR Moderator
- bignickolsonFeb 07, 2019Aspirant
Bumping this. I have a Nighthawk x6 r8000 and a nighthawk EX8000 extender
Router is firmware V1.0.4.28_10.1.54
Extender says there is no new firmware available
I used to have my router have separate SSIDs for 2Ghz and 5Ghz bands. The extender connected to and extended both.
I recently change so both use the same SSID/password. The extender can see my 2.4ghz band and both 5ghz bands, all the same SSID. But when I try to setup the extender it never connects to the 5ghz band.
I've rebooted, I've done it with them sitting 2 feet apart but nothing seems to work. I go through the setup and it connects to the 2.4ghz band but tells me it can't connect to the 5Ghz band.
Any thoughts
- Christian_RApr 16, 2019NETGEAR Employee Retired
Hello bignickolson,
Thank you for your post. If you're still experiencing issues, have you gotten a chance to take a look at the KB article linked below? The following article suggests that you change the wireless channel on your home router to see if the connectivity improves.
Looking forward to hearing back from you!
~Christian
