ryantonk
Nov 06, 2018Tutor
ex8000 extender 5ghz connection
I cannot get my EX8000 to connect to my home routers 5ghz channel, it will only connect to the 2.4ghz channel. I have a AC1750 / C6300 home router. I have tried changing 5ghz channels on the router a...
bignickolson
Feb 07, 2019Aspirant
Bumping this. I have a Nighthawk x6 r8000 and a nighthawk EX8000 extender
Router is firmware V1.0.4.28_10.1.54
Extender says there is no new firmware available
I used to have my router have separate SSIDs for 2Ghz and 5Ghz bands. The extender connected to and extended both.
I recently change so both use the same SSID/password. The extender can see my 2.4ghz band and both 5ghz bands, all the same SSID. But when I try to setup the extender it never connects to the 5ghz band.
I've rebooted, I've done it with them sitting 2 feet apart but nothing seems to work. I go through the setup and it connects to the 2.4ghz band but tells me it can't connect to the 5Ghz band.
Any thoughts
Christian_R
Apr 16, 2019NETGEAR Employee Retired
Hello bignickolson,
Thank you for your post. If you're still experiencing issues, have you gotten a chance to take a look at the KB article linked below? The following article suggests that you change the wireless channel on your home router to see if the connectivity improves.
Looking forward to hearing back from you!
~Christian
