Ibaroj's avatar
Ibaroj
Tutor
Aug 03, 2024
EX8000 extender disassembly
I am diagnosing a dead EX8000 and cannot see how to release the bottom half of the case. Nothing found in searches. There are only two screws at the top so there must be a trick to unlatching the bottom stand portion.
  • The case is quite different from the Orbi though. But I solved my problem, with a Dremel tool lol. After a couple of days struggling I cut thru the seam. That'll show 'em!
    An exploded view would have come in handy; couldn't find anything.
  • plemans's avatar
    On the orbi's, the rear plastic cover that the ethernet ports come in can be removed. Considering the EX8000 is basically the RBR50, that could be a similar attachment point.
    • Ibaroj's avatar
      Ibaroj
      Tutor
