alexnescalante
Sep 11, 2018Initiate
EX8000 w/ R7800 loses connectivity randomly
Using 2 EX8000 nodes (both running V1.0.1.164, both have also been restored to factory after version upgrade)
Router: Nighthawk X4S R7800 (v. 1.0.2.58)
Issue:
EX8000 node will lose connecti...
DexterJB
Sep 14, 2018NETGEAR Moderator
Hi alexnescalante,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
davekimdolan
Feb 15, 2019Aspirant
I, too, am losing connectivity in the same way--lights remain on and connected but no wifi. This has been going on for months occasionally but has increased to at least three or four times/day over the last week. Please advise. I do have the latest firmware.
- mulgrewMar 22, 2019Aspirant
had this same problem using Netgear - Nighthawk X10 AD7200 Tri-band Wi-Fi Router with ex8000 to extend the range, i have now split the 2.4 and 5 ghz channels and turned off smart connect on both the router and extender and so far seems to have solved the problem
