MontecitoCDD
Aug 23, 2018Aspirant
EX8000 Wifi Mesh Extender vs Access Point
Is this correct setup.
I have my cable modem with a lan cord out of it plugged into one of two Nighthawk X6S AC3000 EX8000 devices. This first Nighthawk device operates as a WIFI Access Point t...
MontecitoCDD
I will check that out. Is I have the 2nd device run as an Access Point also, can it use the same WIFI SSID as the 1st access point so people can move freely between them without having to connect to another one? I bet the issue is though it would show up twice on the list.
Aug 23, 2018Guru - Experienced User
You should be able to use the same WiFi SSID/Passphrase. BSSIDs will be different (but that's also true in extender mode).
AFAIK, clients will see the same WiFi advertisements either way. Smart roaming might behave a bit differently, but if your 2nd device isn't near the first, then the clients should switch to the 2nd EX8000 anyway.
