Kwenda
Nov 10, 2017Apprentice
EX8000 WiFi Range Extender installation
Purchased the new EX8000 range extender and used WiFi and the Netgear Installation Assistant to set it upwith a Netgear R7800 router. Downloaded the Netgear WiFi Analytics app and the Netgear gen...
- Nov 13, 2017
Hi Kwenda,
EX8000 is a tri-band extender and uses one of the bands to exclusively(dedicated) connect to the router. Depending on the router's channel the dedicated band can be a 2x2 or a 4x4. When you change the router to recommended channel (say channel 149), the extender will choose the 4x4 to connect to the router and that way you can place your extender farther away from router within the house. Secondly (this may not apply to your case), to avoid interference on router from other wifi, it's better to keep router's channel to high 5G band. Hope this helps!
arunkmony
Nov 13, 2017NETGEAR Employee Retired
Hi Kwenda,
- KwendaNov 15, 2017Apprentice
Thanks for this explanation. I now understand the logic behind the operation of the EX8000, and why the WiFi channel change on the router was recommended.
Thanks
