AFG034
Dec 16, 2019Aspirant
EX8000
So randomly my Netgear EX8000 will lose connection from router its extending however when I look at the setting for the original signal, I can still access it.
For example, a device connected to the extender will lose connection but if I switch to the router, I connect fine. Why would this happen?
What firmware is on your EX8000?
What router are you connected back to?
Have you tried changing your routers wifi channel (which will change the extenders backhaul channel)? Maybe there's interference on the backhaul channel and its causing issues?
How large is your home? Material your interior walls are made of?
How far from the router is the extender?
many things can impact wireless connections. the EX8000 uses the wireless backhaul for connection and if there's interference, its going to create problems. the goal is to figure out how to optimize it.
- AFG034AspirantWhat firmware is on your EX8000? - should be the most up to date.
What router are you connected back to? - Standard Verizon Fios router.
Have you tried changing your routers wifi channel (which will change the extenders backhaul channel)? Maybe there's interference on the backhaul channel and its causing issues? - I have not changed any channels. That’s not something I’m overly familiar with.
How far from the router is the extender? - the router and extender are on the same floor. Router in the front part of the house and extender in the middle. I live in an apartment and my landlord has the router and I use the extender.
many things can impact wireless connections. the EX8000 uses the wireless backhaul for connection and if there's interference, its going to create problems. the goal is to figure out how to optimize it.- plemansGuru - Experienced User
AFG034 wrote:
What firmware is on your EX8000? - should be the most up to date.----Not helpful. It changes frequenly and many times someone has said "the latest" and it isnt'
What router are you connected back to? - Standard Verizon Fios router.---again, not helpful. an extender is only as good as the router its connected to. If the router is poor, the extenders going to be poor as its reliant on the router.
Have you tried changing your routers wifi channel (which will change the extenders backhaul channel)? Maybe there's interference on the backhaul channel and its causing issues? - I have not changed any channels. That’s not something I’m overly familiar with.-----its something that needs to done. If you're living in an apartment, there's more wifi signals around and because of this, is going to have more interference. making sure you're on the best possible wifi channel for the backhaul and the usable signal is key for making extenders work well.https://lifehacker.com/which-wifi-channels-should-i-use-for-my-wireless-networ-1832788063?customKinja=1637678490
How large is your home? Material your interior walls are made of?------? interior wall materials make a big difference as well as placement. Sometimes moving an extender a couple feet can make a big difference if there's hvac/etc within the walls causing issues.
