tkmphx1
Apr 10, 2025Follower
EX8000
Have a EX8000 the set up network NETGEAR_EXT is visible in iPhone as a known network. Cannot add or connect to.
tkmphx1 wrote:
Have a EX8000 the set up network NETGEAR_EXT is visible in iPhone as a known network. Cannot add or connect to.Did you leave something off the end of that message?
I can't tell what is going on.
Disclaimer: Just another user with time on their hands.
could be someone elses.
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
