RCDSOUZ
Jul 26, 2026Aspirant
EXS27 BE5000 Constantly Dropping!
I have this issue SINCE I PURCHASED this expensive wifi7 extender. ALL my IOS devices continue to drop for 10-30 seconds on a daily basis. WITH NO FIX insight. no matter any update i do. The realbi...
RCDSOUZ
Jul 28, 2026Aspirant
My main Nighthawk RS700 router is top floor
Extender in middle floor
I have played around with those channels you mentioned with no help.,
There is only 5 networks around
Firmware 1.0.1.34
Jul 28, 2026Guru - Experienced User
Distance in between the host wifi router and EXS extender?
What FW is on the RS router?
- StephenBJul 28, 2026Guru - Experienced User
StephenB wrote:
Try measuring the main wifi speed at the extender location (with the extender off). Use the free Ookla speedtest app. In extender mode, it needs a solid connection to the main router.
Please respond to both of these requests.
- RCDSOUZJul 30, 2026Aspirant
about 25-30ft (Walking from office on top floor to middle floor where i have extender located.
RS700 - Firmware Version V1.0.11.8_2.0.112- StephenBJul 30, 2026Guru - Experienced User
Ok. And if you turn off the extender, and measure your wifi speed on your phone at the extender location, what speed to you get?
The extender needs to have a solid connection to the router wifi - if it doesn't, then you will see connection drops that match your symptoms. (device connected to extender wifi, but cannot reach the internet).
- FURRYe38Jul 30, 2026Guru - Experienced User
Might try the extender maybe a bit farther and see if it still happens.
Keep in contact with WarmHelp_NTGR
I think a better way to confirm the backhaul connection quality is just to measure it using your phone (as I've suggested more than once).
25-30 feet should be far enough away to ensure no interference from the router. But something could easily be blocking the signal path - a pipe chase, chimney, heating system ducting, etc.
