brendabugaloo's avatar
Mar 20, 2020
EXT2700 - PURCHASED USED, EXTENDER WILL NOT RESET TO FACTORY MODE
Hello,
I am having trouble getting my wifi extender to pop up on my wifi managers on my devices. Only one extender pops up under the name Werkartz I believe and when it is unplugged it does not appear. We have attempted to reset it to factory mode 4 different times, holding down the button for 5-10 seconds each time and it still appears as the old name. I cannot connect to it therefore I don't have access to change anything.
I purchased this used on amazon and was wondering if someone could walk me through this.
I hope you are well, kind regards,
Brenda
1 Reply
  • plemans's avatar
    brendabugaloo wrote:
    Hello,
    Brenda
    When you're pushing and holding reset, is the device plugged in? When you've held the reset button long enough, the lights will change. its usually 7-15 seconds but some have needed up to 30 seconds.
