Technolocloud
Nov 20, 2016Aspirant
Extend with Ethernet?
I currently have an R7900 and an EX7000 and the wireless extension is via wireless radio. Does Netgear or any other vendor on the residential side have an extender that can leverage an ethernet conn...
TheEther
Nov 21, 2016Guru
I'm not entirely sure what you're asking for so I'll describe the two ways Ethernet can be used with an extender.
- Internet====Router====Wi-Fi====Extender====Ethernet====Wired Device(s)
All extenders support this. - Internet====Router====Ethernet====Extender====Wi-Fi====Wireless Device(s)
Only extenders that support Access Point (AP) mode support this.
- TechnolocloudNov 21, 2016Aspirant
Oops...missed the important part of that question.
...using SAME SSID. I know enterprise products can do this with a bit more complex set up obviously and many times with a controller device.
In the case of my R7900 and EX7000, the EX7000 has different SSIDs than the base station.
When I tried to tie together two R7000 Nighthawks, it wanted encryption turned off to use both as a base/repeater setup. Who the heck would want an open wireless network?
- DarrenMNov 22, 2016Sr. NETGEAR Moderator
Hello Technolocloud
What wanted the encryption turned off it should let you password both of them.
DarrenM
