Aarontography's avatar
Dec 06, 2019
Extended is blocking XBOX NAT
2 days ago,my XBOX NAT started showing "Getting info".And doing a NAT test gave a "can't get a teredo ip"from the XBOX.When I connect to the main router,and even my phone,it shows open.And when I connect my desktop to the extender,and login to XBOX settings,it shows open NAT.So for some reason,the extended started blocking my XBOX from the NAT,but it has internet access.
Any ideas?
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Aarontography,
    You may have to port forward the IP address of the extender and the xbox on the router. I would also check for a firmware update on the extender and factory reset to run through the setup assistant again.
    Christian
