Svelen
Mar 02, 2018Aspirant
Extended net don't accept router's wireless key
My extended wifi-net don't accept the wireless key used by the 'base' net. Need Your help! From real winter in Sweden // Sven
- Mar 04, 2018
Setting the Security Mode to WPA PSK seems to do the trick. Now I have an extended wifi and with some security.
Creds to you for the support // S
jvasanth1984
Mar 04, 2018Virtuoso
Hi Svelen,
Please cross check the password which you are trying during setup. Also, make sure access control/MAC filtering is turned OFF on your main router. If both are done, try changing the channel on router which should resolve the issue.
Svelen
Mar 04, 2018Aspirant
Thanks for your input.
BUT the solution(?!?!) seems to be to switch off any security option, neither WEP or WPA is accepted.
There must be an alternative to no security at all! // Sven
- jvasanth1984Mar 04, 2018Virtuoso
Hi Svelen,
Extender support WEP/WPA as well as WPA2 securities. Also, if access control/MAC filtering is enabled on router, you need to add virtual MAC address of extender to the access control/MAC filtering list and then try setting up the extender which should work.
- SvelenMar 04, 2018Aspirant
What do you mean by control/MAC filtering? I see no such possibilty on my router.....
Hi Svelen,
May I know the make and model of your router so that I can look for it?
