Svelen
Mar 02, 2018Aspirant
Extended net don't accept router's wireless key
My extended wifi-net don't accept the wireless key used by the 'base' net. Need Your help! From real winter in Sweden // Sven
- Mar 04, 2018
Setting the Security Mode to WPA PSK seems to do the trick. Now I have an extended wifi and with some security.
Creds to you for the support // S
jvasanth1984
Mar 04, 2018Virtuoso
Hi Svelen,
May I know the make and model of your router so that I can look for it?
Svelen
Mar 04, 2018Aspirant
technicolor TG799TSvn v2
- jvasanth1984Mar 04, 2018Virtuoso
Hi Svelen,
Below link will explain about access control of your gateway and to check if it is enabled or not.
https://www.manualslib.com/manual/712507/Technicolor-Mediaaccess-Tg799vn.html?page=113
Hi Svelen,
Would like to know if that helped or you still encounter issues.
- SvelenMar 04, 2018Aspirant
