Svelen
Mar 02, 2018Aspirant
Extended net don't accept router's wireless key
My extended wifi-net don't accept the wireless key used by the 'base' net. Need Your help! From real winter in Sweden // Sven
- Mar 04, 2018
Setting the Security Mode to WPA PSK seems to do the trick. Now I have an extended wifi and with some security.
Creds to you for the support // S
Svelen
Mar 04, 2018Aspirant
technicolor TG799TSvn v2
jvasanth1984
Mar 04, 2018Virtuoso
Hi Svelen,
Below link will explain about access control of your gateway and to check if it is enabled or not.
https://www.manualslib.com/manual/712507/Technicolor-Mediaaccess-Tg799vn.html?page=113
- jvasanth1984Mar 04, 2018Virtuoso
Hi Svelen,
Would like to know if that helped or you still encounter issues.
- SvelenMar 04, 2018Aspirant
Hi Svelen,
Good to know that it worked.
