Svelen
Mar 02, 2018Aspirant
Extended net don't accept router's wireless key
My extended wifi-net don't accept the wireless key used by the 'base' net. Need Your help! From real winter in Sweden // Sven
- Mar 04, 2018
Setting the Security Mode to WPA PSK seems to do the trick. Now I have an extended wifi and with some security.
Creds to you for the support // S
jvasanth1984
Mar 04, 2018Virtuoso
Hi Svelen,
Would like to know if that helped or you still encounter issues.
Svelen
Mar 04, 2018Aspirant
- jvasanth1984Mar 04, 2018Virtuoso
Hi Svelen,
Good to know that it worked.
