Tdraym's avatar
Tdraym
Extender connected
I have a ax1600 extender if all for lights are showing steady green is it connected to my main router
I have  many questions but the last time tried to publish one it wouldn't let so let's start here
  • plemans's avatar
    What router are you connected to?
    The EAX12 is a mesh extender so when setup in default setup, it won't show as separate network. Just one.
    And if the lights are green, its connected and working.
    If you want to access it, log into your router and look at its attached devices page. The extender should be on there with an IP address. Use that address to log into it.
  • AX1600 4-Stream WiFi 6 Mesh Extender (EAX12)   Serial
    Number: is registered with netgear
    Bought 11/28/2025  is all info . on my netgear page
    • StephenB's avatar
      on my netgear page
      This is a user-to-user forum, so this doesn't help us.
      Can you reach the internet when you are connected to the extender wifi?
  • CrimpOn's avatar
    CrimpOn
    AX1600 is a marketing term that is used with several products.  Can you please indicate exactly which product this is? (from the product label)
  • I have tried website to see status, no luck, iI have tried app, nighthawk no luck tech support didn't help so it's a long story ,extender only 10 days old
