MisterJenks's avatar
Jun 29, 2021
Extender connection issues. Stuck in factory reset mode.
My extender lost connection a few days ago. I switched the power off, but when I restarted it all of the LED lights on the front are flashing white. The power button light on the back of the extender is also flashing green.
I tried to do a factory reset on it to see if that would help, but it has still stayed the same. I can't even log on to my extender as it keeps showing that the extender is not switched on when I enter the ip address for it.
I have no idea what to do to fix this or if there is actually a problem with my extender? I'm not very good at looking through technical documents and trying to work the IT side out for myself. Does anyone have any ideas or suggestions as to what I could do to fix this?
Thanks in advance
David
