sopralto817
Sep 07, 2017Follower
Extender constantly not connecting to main wifi unless I restart it
For some time now, my wifi extender has been regularly (Longest time I've gone between having a problem has been maybe three or so days) refusing to connect to the main wifi, and will only do so if I...
DarrenM
Sep 11, 2017Sr. NETGEAR Moderator
Hello sopralto817
When doing the setup again have you tried to move it to the same room as the router then set it up then move it back to the place you had it?
DarrenM
