Danilo11
Oct 02, 2020Tutor
Extender disconnects at specific time each day
Hi I have Hardware Version: WN3000RPv3 Firmware Version: V1.0.2.86 At a specific time each day, all the devices that are connected to my extender, are disconnected for almost a minute, a...
Oct 03, 2020Guru - Experienced User
What router is the extender connected to?
have you assigned a static ip address to the extender from the router? It sounds like the dhcp lease is expiring and renewing.
- Danilo11Oct 05, 2020Tutor
Hi
Yes, I assigned a static IP address to the extender.
And, yes, the lease time is exactly 12 hours.
I changed it to a longer period, so this should solve the problem.
However, it is not clear to me why the extender had such a weird behaviour.
Before I had another extender (of a different brand) and this never happened.
Is something related to specific settings of this extender?
Thank you for your help
- plemansOct 05, 2020Guru - Experienced User
it could just be that that device was originally made in 2013.
Again, not sure what router you have but if it doesn't automatically renew/update the dhcp issue and the extender is a older device, it could just need the static address to ensure the connection.
Just throwing ideas out there.
- Danilo11Oct 06, 2020Tutor
Thank you for your answer
The router is a "basic" one provided by my ISP.
However, I changed the DHCP lease time to one month (744 hours), but I still have the same issue.
I have restarted the extender several times (and I have also kept it off for several hours), but the situation did not change.
It always disconnects at a specific time every 12 hours (the exact time should at least change, since it has been closed for several hours, right?).
Do you have any other suggestion that I can try?
Thanks
