Danilo11
Oct 03, 2020Tutor
Extender disconnects at specific time each day
Hi I have Hardware Version: WN3000RPv3 Firmware Version: V1.0.2.86 At a specific time each day, all the devices that are connected to my extender, are disconnected for almost a minute, a...
Oct 06, 2020Guru - Experienced User
Did you install it via wps?
If so, try factory resetting and installing using the installation assistant.
Danilo11
Oct 06, 2020Tutor
Yes, I installed it via WPS
I will try with the Factory Reset and the "manual installation", as you suggested
Thanks
- Danilo11Oct 07, 2020Tutor
Unfortunately it did not work.
Do you have anything else to try?
Thanks
- plemansOct 08, 2020Guru - Experienced User
Maybe try downgrading the firmware a version?
- Danilo11Oct 08, 2020Tutor
Actually, I have just updated it a few days ago.
Let me clarify it.
4/5 weeks ago I noticed this problem (probably was there even before and I did not notice it).
I tried several solutions (even resetting multiple times), but none of them worked.
A few days ago, I logged in the extender webpage and it told me that there was an update.
I thought that this could solve the problem, so I updated it.
But unfortunately it did not solve it.
I think that was the first time I updated the extender (a part from when I bought it), so I do not think the problem was in an update.
But I can try to downgrade to an older version.
Do you have a specific one to suggest me?
Thanks
