Danilo11
Oct 03, 2020Tutor
Extender disconnects at specific time each day
Hi I have Hardware Version: WN3000RPv3 Firmware Version: V1.0.2.86 At a specific time each day, all the devices that are connected to my extender, are disconnected for almost a minute, a...
Oct 08, 2020Guru - Experienced User
If the downgrade doesn't work, the only other thing I'd have you try is a different router. Maybe see if it works fine at a friends, neighbors, family members router. Or even an old router if you have one.
The router is still the backbone of the system. If its still whats causing the issue (and isp supplied routers aren't known for stellar performance/features), nothing we change on the extender is going to help.
Danilo11
Oct 08, 2020Tutor
The downgrade did not work.
I have not tried yet with another router, but I connected another extender (of another brand) to the same router and that one seems to work fine.
Does this help with the diagnosis of the issue?
Thanks
- plemansOct 09, 2020Guru - Experienced User
Not really.
It could still be the router having issues with netgear or it could be the extender just being bad. Its why I'd try it with another router.
You could even try hardwiring it in and using it in access point mode. https://kb.netgear.com/25715/How-do-I-install-the-WN3000RPv3-as-an-access-point
