Buck567's avatar
Buck567
Tutor
Apr 09, 2021
Extender e2700
My extender was working fine until recently it no longer receives internet. The lights are on the extender, it shows as a WiFi network on my devices, but when I connect to (my network)_ext WiFi network, I do not have internet to my connected devices. This is a new problem and nothing else has changed with my home internet. I have tried restoring factory settings, re-connecting the extender multiple times.
  • No, for setup the laptop doesn't need to be online. It just needs to be connected to the internet. Thats why I usually recommend disabling the wifi, so the laptop doesn't default back to the wifi connection during setup
  • plemans's avatar
    What router do you have?
    Are you setting up using wps or using the installation assistant?
    • Buck567's avatar
      Buck567
      Tutor
      I have an At&T router. I initially set up the extender either wps (?assume this is wireless). Everything worked fine for many months. Then, all of a sudden, all connected devices are “offline” even though the router and device lights are green on the extender. I have tried to reconnect via Ethernet and the computer, but no success.
      • plemans's avatar
        try factory resetting it and then reinstalling using the installation assistant.
