PantherTank's avatar
PantherTank
Extender ex6100v2/AC750 ONLY GREEN POWER LIGHT ON.
Hello, my extender is not working, only green power light is on. I have had the extender for a couple of years with no issues. Have tried factory reset with power off and then saw a post saying you had to turn it on, so I turned it on. I waited for the power light to go green and then pressed the reset button, the power button started flashing. and then the extender light came on red then the power light went solid green then the extender light went off. So back to green power light on only again. Turned it off then back on and reset it with the power light at orange. Same thing happend and back to Green light on power only. Not sure what to do.
  • plemans's avatar
    Did you try hardwiring a pc/laptop into it and setting it up using the installation assistant?
    • PantherTank's avatar
      PantherTank
      I did what you said and it goes to the setup screen. It asks me to select an existing network I would like to extend. It scans for a network, it finds the one I want, i select it and then there are two buttons BACK and NEXT but I can't select NEXT it is greyed out
      • plemans's avatar
        If you didn't fill in all the fields, it doesnt' let you advance.
        did you fill them all in?
        Have you tried a different browser/pc?
