Poetryking's avatar
Poetryking
Extender for use Netgear R7450
I need to extend the range in my house.  What is the best way (and cost effecient) to extend the range of my router to a garage 100 feet away?
  • plemans's avatar
    Best?
    Probably bury an underground ethernet wire and connect an access point.
    Might even be the cheapest if you bury the wire yourself.
    100ft is a bit of distance if you're going through 2x exterior walls.
    • Poetryking's avatar
      Poetryking
      If we only needed to go 50 feet, is there a plug and play extender that works well with this router?
      • plemans's avatar
        It all depends. Its not always about distance.
        If the home's exterior wall is brick and the shed, it might be blocked 100%.
        Certain materials block wifi better than others. And an extender still needs a signal.
        Stand where you think the extender will be with your phone and see if you can get a usable signal.
        If you don't, the extender won't either.
