CoxMartin
Jun 16, 2017Tutor
Extender keeps dropping connections
Started to get issues where the device (set as an extender) is being not able to maintain a connection to my Mac. The Mac can connect to the main router, so the issue does not appear to be there. C...
netwrks
Jun 16, 2017Master
It supports Access Point mode. Save yourself thegrief and configure it as an AP..
CoxMartin
Jun 16, 2017Tutor
That kind of defeats the objective. The cheaper AP only option has been tried previously, but due to a none standard mains power configuration (two totally isolated circuits) does not work. So the extender is a must, and the functionality claimed by the device.
Looks like this device will be joining the dedicated AP ones in the landfill then :-(
- netwrksJun 16, 2017Master
IMHO extenders are a waste of time, even on expensive devices. Too many variables for wireless and then, intorducing extenders. Ethernet is the way to go.
- CoxMartinJun 16, 2017Tutor
Starting to agree, it is just a shame that Netgear market this as having extender capabilities! They should have added "if you are lucky, and the wind is in the right direction".
Totally with you on the ethernet, but if you saw the task that is going to be for me (up three floors, 50mtrs across loft space and down one floor ) you would know why I opted for the extender LOL.
- kessencyJun 29, 2017Aspirant
I have the same problem with this range extender. It totally defeats the purpose of a range extender if I have to run ethernet cable, which I cannot in a house that is almost 30 years old. I am still in the 90 day period but cannot return to Best Buy as it have to return within 30 days. This is nuts.
