KamleshR
Apr 07, 2023Tutor
Extender N300
recently I changed my network provider and and even after resetting factory settings the extender does not recognise the new password.
I have model WN3000RPv3 and the new network is recognised but comes up with incorrect password. I know the password d correct as all other devices connnect.
Can anyone help please?
i cannot get to the setup assistant webpage.
thanks
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk- KamleshRTutor
Thanks for the suggestion and taking time to respond.
I tried this but could not get to the Assistant. I think I will just go and buy a newer version. - KamleshRTutor
Hey, i had another go, based on your suggestion and video, and it worked !
many thanks, it's much appreciated.
Glad it worked! you might mark it solved so others aren't still trying to fix it.
