TFUDD91's avatar
TFUDD91
Follower
May 22, 2016
Extender Network Password
So i just set up my extender network and i thought it had just autopopulated the same password from my router. When i went to get on the extender network the password would not work and now i'm stuck...
  • DarrenM's avatar
    May 25, 2016
    Hello TFudd91
    If your password is not working you will have to do a factory reset and do the setup again to get the password to what you want it to be.
    DarrenM
