rapattack
Mar 29, 2018Aspirant
Extender not working?EX6100 WiFi Range Extender
I did the wps setup through my router as i got nowhere trying to do it thru the wps button. Seems with my router that button also resets and takes away the password i set and thats no good. Anyway se...
- Apr 03, 2018
i got on the phone today and called them. It took maybe 2 hours and we finally got it to work. The tech person had to take control of my computer and all the things i saw looked the same as the manual. So i really dont know why it worked for her and not me. The result was though is the signal is very bad...the extender part of this device is not very good. So i said to her what about we try it as an access point. It has a switch on the side. It worked and it is so much better. Because i have the modem separate form the router and the modem does not have wifi plus it is located where the bad signal is then i was able to put a cable in the modem and use this device as an access point. If you know what i mean? Because the tech person didnt originally know my network setup she wouldnt not have known this could be done. Now i have to test later if the signal reaches outside
Froghair
Apr 03, 2018Aspirant
I am having same issues with my EX6100. I changed my ATT router to model BGW210. I followed instructions to install extender to ATT router and get the WPS green lights on the router and extender and the green router link led in the upper left top. My laptop shows that I am using the ATT router address but there is no Netware -2GEXT or -5GEXT to choose from like my first ATT router. I am not WI-FI connected in the Netgear Support pages and none of the link addresses are helping me to install the genie Smart Setup. I have made numerous attempts using the manual and online help but no luck so far. What do you think I am doing wrong? Thanks
rapattack
