rapattack's avatar
rapattack
Extender not working?EX6100 WiFi Range Extender
I did the wps setup through my router as i got nowhere trying to do it thru the wps button. Seems with my router that button also resets and takes away the password i set and thats no good. Anyway se...
  • rapattack's avatar
    rapattack
    Apr 03, 2018
    i got on the phone today and called them. It took maybe 2 hours and we finally got it to work. The tech person had to take control of my computer and all the things i saw looked the same as the manual. So i really dont know why it worked for her and not me. The result was though is the signal is very bad...the extender part of this device is not very good. So i said to her what about we try it as an access point. It has a switch on the side. It worked and it is so much better. Because i have the modem separate form the router and the modem does not have wifi plus it is located where the bad signal is then i was able to put a cable in the modem and use this device as an access point. If you know what i mean? Because the tech person didnt originally know my network setup she wouldnt not have known this could be done. Now i have to test later if the signal reaches outside
