Kabina
Jan 15, 2023Follower
Extender only outputs 5GHz, can't connect to 2.4GHz
I have myself an EX7000 wifi extender, I have it set up in a shed outside my home so i can have good internet access for myself and a handful of smart devices when out there. When setting it up and c...
rostones
Apr 08, 2024Aspirant
The issue with 2.4GHz is that it experiences higher interference due to its slower speed, fewer channels, and wider broadcast range, making it more susceptible to signal disruptions.
You can experiment with different 2.4GHz channels on the router to potentially alleviate the problem.
Another option is to consider downgrading the firmware on the extender to investigate whether the issue stemmed from a firmware-related issue.
