Gwyny
Dec 06, 2016Aspirant
Extender password unaccepted
I plugged my new WN1000RP in and tried to connect but keeps telling me my password is incorrect. I am entering it correctly. Why won't it accept
- Dec 14, 2016Thanks Darren. I finally got it going by doing what the idiot sheet told me to in first place but hadn't read it properly!! Plugged it in right next to the modem (which is in building next door) and it connected automatically. My problem was being the second extender on the system the first had .ext and mine was .EXT but when I first tried it away from the modem it came up .ext.EXT so wasn't recognised. Anyway all Good now. Thanks and Merry Christmas!!!
Gwyny
Dec 10, 2016Aspirant
This is the second extender I'm trying to connect to main router. The first has the routers network name ending with .ext and this 2nd one ends with .ext.EXT.
Is this causing a problem do you think?
DarrenM
Dec 12, 2016Sr. NETGEAR Moderator
Hello Gwyny
The other way you can try to connect to the extender is on your main pc log into your router then go the that attached devices then find the ip address of the extender. After you got the ip address put that into your web browser and that should prompt the login.
DarrenM
- GwynyDec 13, 2016Aspirant
I'm a bit slow today Darren, about as slow as my laptop! What do you mean by log into my router? I'm using Windows 10 and if I click on the wifi icon lower right of screen and the wifi options come up which show I'm connected how do I then log into it and find attached devices?
- DarrenMDec 14, 2016Sr. NETGEAR Moderator
Hello Gwyny
I do not know what router you have but typically to get to the settings in your web browser and type 192.168.1.1 or 192.168.0.1 and it should prompt you to log in to the router. You would have to look up the login info for your router but if its a netgear router it will be admin/password
DarrenM
