KevinKesler
Aug 29, 2016Aspirant
Extender plus dhcp
I need basic router functions to host several devices and network them together. I also need the router to pickup an available outside wifi signal and share it inside this network.
KevinKesler
Sep 02, 2016Aspirant
Scenario
I have a ex6200
2 laptops
2 tablets connected to ex6200
Ex6200 assigning addresses (dhcp)
Ex6200 connecting to the Hotspot on my cell phone for internet connection.
Ex6200 sharing internet connection with all its connected devices
I need step by step help with this, since I can't seem to figure it out.
I have a ex6200
2 laptops
- DarrenMSep 07, 2016Sr. NETGEAR Moderator
Hello kevinKesler
The issue you might have is the Ex6200 cant do DHCP its only a extender you would need some type of router you may want to check out the R7100LG if you are using cell internet you can put a sim card in it.
https://www.netgear.com/support/product/R7100LG.aspx?cid=wmt_netgear_organic
DarrenM
