ute_zi
Dec 24, 2021Aspirant
extender refuses client connection
I extablished a connection from the extender WN3000RP to my Fritz!Box 5330 via WPS (2.4 Ghz) and I can connect to the extender web page via its assigned IP address. I can not connect any client to ...
ute_zi
Dec 25, 2021Aspirant
thank you plemans for your reponse!
connecting the extender to the router is not the problem.
using WPS or the assitant, it always connects without problems.
conneting the mobile clients to the router works as well without problem.
it is when I want to connect the mobile client to the extender that I cant connect.
nielsvds
Dec 25, 2021Luminary
I would try a reset of your network settings.
Android phone: https://www.howtogeek.com/710873/how-to-reset-network-settings-on-android/
Iphone: https://support.apple.com/en-us/HT204051 (step 7)
Windows system: https://www.howtogeek.com/265870/how-to-reset-your-entire-network-in-windows-10-and-start-from-scratch/
Are you using fixed IP addresses or dynamic IP addresses (DHCP)?
