EdVT's avatar
EdVT
Extender stopped working
I have had an AC1200 Extender for 5 years and has worked well and recnelty jsut stopped working.  I Have direct line to the extender.  All connections have been check and the extender has all the apropriate lights.  But when you try to use the wifi signal it says the device is not connected to the internet..
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi EdVT, please indicate the exact model of the extender and the firmware version it is on. Also, have you tried resetting it back to factory settings and going through the setup again?
    Dexter
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi EdVT, I would like to follow up and check if you are still experiencing the issue.
      Dexter
      • EdVT's avatar
        EdVT
        Thanks for the advice.  I did have to do a factory reset and start over, but working now.
        Ed
