gphoto's avatar
gphoto
Follower
Sep 03, 2016
Extender to pair with WNR2000v3 router
We have a N300 Wireless Router/WNR2000v3. We've moved into a larger two-story house with some not quite dead zones, more like stagnant ponds. Also, our streaming device is struggling.
Which router extender would be a good fit?
I was looking at the AC1200/EX6200 and the N600. I figure I'd getter better advice here than at a big box store.
Also, how difficult are these to set up?
We're a Mac-based household and our streaming device is an Amazon Fire box.
Thanks in advance.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello gphoto
    That extender will work just fine for you and they are really simple to setup you can use WPS or you just log into the extender and go through a smart wizard setup.
    DarrenM
