TheITWizard
Nov 04, 2018Aspirant
Extender will not connect to router that is using smart connect
How should I set up a Netgear range extender when Smart Connect is enabled on my router? I have R6700v2 router and EX8000 extender. The extender wants to deal with router bands discretely. In the ext...
Nov 04, 2018Guru - Experienced User
TheITWizard wrote:
the ability of the router's Smart Connect to assign a band to the extender dynamically?
Ultimately the wifi clients choose what band they want to use - the router can offer hints, but that's about it. Generally clients will follow those hints.
TheITWizard wrote:
In the extender setup, do I choose the same SSID in both the 5GHz and 2.4GHz bands
Yes, and of course you have to do that since the networks have the same SSID.
Are you saying that this isn't working, or are you simply asking the question?
TheITWizard
It is not working. It appears that when the router is using sma rt connect, it will not accept a virtual connection request from the extender. This is a tri band router and only one of the three connections gets an IP address from the router dhcp. The other two connections do not, they are virtual connections. With smart connect turn on the router, it will not accept the virtual connections, therefore the extender fails to connection.
I am looking for either a fix for the router or a work around. Any ideas?
- StephenBNov 05, 2018Guru - Experienced User
THE R6700v2 is a dual-band router - 450 Mbps @ 2.4ghz +1300Mbps @ 5ghz, with both bands being 3x3. Did you enter the correct model number in your earlier post?
- TheITWizardNov 05, 2018Aspirant
Yes. Right off the router login page.
Router R6700v2 Firmware Version V1.2.0.24_1.0.1
Extender EX8000 Firmware Version: V1.0.1.186
Ok. Well, the router certainly isn't triband. Were you meaning to say that the extender is triband?
Also, have you confirmed that that the extender works properly with Smart Connect turned off?
